Advantech provides highly expandable and reliable industrial server solutions that use the latest AMD® EPYC™ 9004 series processors based on its “Zen4” CPU architecture, including a single CPU socket ATX motherboard and a dual CPU socket 2U rackmount server and multiple PCI-Express 5.0
Executive Summary
Advantech provides highly expandable and reliable industrial server solutions that use the latest AMD® EPYC™ 9004 series processors based on its “Zen4” CPU architecture, including a single CPU socket ATX motherboard and a dual CPU socket 2U rackmount server and multiple PCI-Express 5.0 slots for add-on board accelerators. They both raise the level of performance and offer flexibility to meet specific applications requirements in areas such as high-end factory automation and control, optical inspection, intelligent manufacturing, warehouse management, and medical imaging applications. With their superior performance and expandability, Advantech’s Industrial Server solutions using AMD® EPYC™ 9004 series processors give businesses more flexibility to meet their exact needs while also lowering TCO and OPEX through, requiring fewer servers to meet the same demand, and also benefitting from greater power efficiency per device.
Advantages of AMD® EPYC™ Embedded 9004 Series Processors
AMD® EPYC™ 9004 series processors use its latest “Zen4” CPU architecture committed to a highly power efficient 5nm chip production process. It offers leadership socket and per-core performance efficiency, new DDR5 ECC RDIMM memory support with advances in security such as memory encryption, plus up to 128 lanes of the latest PCI-Express 5.0 IO. Using the new SP5 socket, AMD® EPYC™ 9004 series processors can offer up to 96 cores and 192 threads per CPU, elevating the performance per node by up to 1.9X compared to previous generation CPUs.
Advantech ASMB-831 Industrial Server Motherboard
The Advantech ASMB-831 is an ATX industrial server motherboard ready for a single AMD® EPYC™ 9004 processor and 6 channel of DDR5 ECC RDIMM 4800MT/s. Advantech recommends EPYC™ CPUs with 240W maximum TDP, providing a strong balance of performance and power efficiency in a compact chassis.
Principally designed for demanding applications that focus on PCI-Express accelerators to do the heavy workloads, 7X PCI-Express 5.0 are available to high-end add-on boards such as AMD Xilinx FPGA cards, multi-NVMe SSD storage cards, and Data Processing Units (DPU). For AI/ML applications that require GPUs, up to 4X double-deck cards can be installed – the most in its class. Storage applications will benefit from the 9X SATA ports and 2x M.2 SSD slots built in. On the rear IO two 10GbE are available for high bandwidth networking, 4X more USB 3.2 Gen-1 (5Gbps) are available for peripherals versus competing products. The motherboard’s server management feature is IPMI 2.0 compliant and Redfish ready, which is built by Advantech’s in-house BMC management technology to provide highly reliable and secure remote access via GbE interface.
Key Features
- 2X faster PCI-Express (Up to 5X PCI-Express Gen-5 X16 and 2X PCI-Express Gen-5 X8)
- New DDR5 technology with faster memory bandwidth (6-channel DDR5 ECC RDIMM at 4800MT/s)
- Two Intel 10GbE (X710-AT2 / RJ45)
- Latest generation IPMI 2.0 (AST2600)
- 9 x SATAIII (8 from SFF-8643, 1 from SATA port)
- 4 USB ports in rear and 3 USB ports onboard for local peripheral devices
- Fewer servers, higher performance, greater power efficiency, lower TCO/OPEX
ASMB-831
AMD® EPYC™ Embedded 9004 ATX Server Board with 6 x DDR5, 5 x PCIe x16 + 2 x PCIe x8, 9 x SATA3, 7 x USB 3.2 (Gen1), Dual 10GbE, and IPMI
Advantech SKY-721E3 HCI & Storage Server
The Advantech SKY-721E3 Server is ready for virtualized workloads and Hyper-Converged Infrastructure (HCI) deployments. Featuring dual AMD EYPC 9004 series processors with TDPs up to 360W each, and 3TB of ECC RDIMM/LRDIMM DDR5 memory, it provides exceptionally high-performance computing performance in a 2U rackmount chassis.
The several PCIe 5.0 slots available create a system ready to meet the needs of a wide variety of application(s) driven by GPUs, FPGA, Data Center-grade DPU networking, or multi-NVMe SSD storage cards with extreme speeds. The 2U rackmount chassis offers high density hot-swappable SAS/SATA storage bays as either 24X 2.5-inch or 12X 3.5-inch options, plus two additional M.2 NVMe SSD drives internally. 1+1 redundant power supplies up to 2kW ensure enough power available for even the most high-end add-on board configurations, while its 80Plus Platinum rating ensures power efficiency is maximized to reduce operating costs. The server system uses the latest ASPEED AST2600 and IPMI 2.0, which is combined with Advantech’s in-house BMC management platform and Redfish to provide highly reliable and secure remote access.
Key Features
- Dual AMD® EPYC™ 9004 series processors up to 360W TDP each
- Designed for expansion using the latest GPU-based AI accelerator cards, high-performance FPGA cards, DPU networking cards, and NVMe storage cards.
- 2X PCIe 5.0 x16 (FHHL)
- 2X PCIe 5.0 x8 (FHFL)
- 2X PCIe 5.0 x8 (FHHL)
- 2X PCIe 4.0 x8 (low profile)
- 1X PCIe 4.0 x16 (OCP 3.0)
- ECC R-DIMM/LRDIMM up to 3TB
- 2X 10GbE (Intel X710) SFP+ and 2X 1GbE RJ45
- IPMI 2.0 (AST2600) remote management
- 1+1 80Plus Platinum PSUs up to 2kW each
SKY-721E3
AMD® EPYC™ Embedded 9004 Short-Depth Server
Application Scenarios
Meeting the Demands of Modern Services Whether installed as part of a device operated directly, or accessed remotely, the Advantech Server solution can effectively meet the demands of factory automation, Industry 4.0/5.0, warehouse and building management, smart city initiatives, modern online services, and emerging AI applications.
- AOI for Real-time Production Line QC
- Medical Imaging Equipment, Diagnosis and Surgery
- Video Transcoding for Online
- Smart Cities and Enterprise
Please download the solution brief to learn more information about the new platforms listed above, which are all available for immediate evaluation and benchmarking. If you are interested in evaluation units, please complete the form. Let's meet the new standard of the modern data center.
