Case 1 - Comprehensive Sanitization with the UV Disinfection Robot
- AI can replace humans with robots during a pandemic to significantly lower the risk of an infection and maintain a safe environment
- The built-in AI is capable of predetermining the optimal path to avoid obstacles.
Case 2 - AI in Medical Navigation
- Dual 4K and full HD video capture cards: The USM-500 comes with two video capture cards supporting 4K and full HD resolutions, enabling seamless capture of large video files and real-time AI algorithm execution.
- Real-time AI algorithm execution: With its video capture cards, the USM-500 enables users to execute AI algorithms in real time, enhancing efficiency and enabling swift insights extraction from captured video footage.
Case 3 - Robotic Assisted Bronchoscopy Platform
- Ensuring stable operations of two high performance computing systems in a single OR kart system.
- Take advantage of the RTX A4000, suitable for real-time image processing in confined spaces.
/HPC-7442_Front-Left_S20160330132651.jpg)
-50/NVIDIA-RTX4000SFF-3QTR-Left-LongBracket_820x82020230522110707.jpg)
-50/RTX_A-Series-A5000_3QTR-TopLeft_820x82020230315201313.jpg)
-50/h100-pci-e-3qtr-right-reverse_820x8202022102717053720240104142817.jpg)
