Advantech DS-540 and ITD-2000 Series displays combine compact, fanless computing with durable touch interaction for kitchen display systems. The solution keeps orders visible, connects kitchen peripherals, and supports efficient back-of-house workflows.
Executive Summary
Advantech combines the DS-540 KDS player with ITD-2000 Series industrial touch displays to create a compact computing and display solution for kitchen workflows. The DS-540 processes order data and connects kitchen peripherals, while the ITD-2000 Series provides a responsive, easy-to-clean interface for viewing and updating order status.
The DS-540 uses an Intel® Processor N150 with a 6 W thermal design power, supports up to 16 GB DDR5 memory, and provides 2.5GbE, HDMI, VGA, USB, and serial connectivity. Its fanless IP40 enclosure, 12 to 24 VDC input, and VESA mounting options support behind-display installation and long operating hours.
The ITD-2000 Series adds 10-point projected capacitive touch, glove support, an anti-glare FHD panel, and a true-flat IP65 front with IK08 impact resistance. Together, the products provide a practical platform for order routing, kitchen workflow updates, menu preparation status, and back-of-house control.
Application
Kitchen Display Systems and Back of House Order Management
Customer Challenge
Kitchen operations require fast information flow and dependable hardware. The system must remain readable and responsive while fitting into space-constrained areas that require frequent cleaning and access to multiple peripherals. Peak-hour visibility: Kitchen staff need clear order status and preparation sequences to manage high volumes without missed or duplicated orders. Environmental Exposure: Dust, food debris, splashes, heat, and frequent cleaning can shorten the service life of consumer-grade computers and displays. Peripheral Integration: KDS deployments may connect scanners, printers, controllers, networks, and legacy serial devices, creating cabling and compatibility challenges. Serviceability: Behind-display installations must stay compact while allowing fast maintenance and replacement with minimal disruption to kitchen operations.
Solution Architecture
Kitchen Workflow Computing
The DS-540 operates as the KDS edge player, receiving order data and driving kitchen displays in real time. Right-sized Performance: The Intel® Processor N150 and up to 16 GB DDR5 memory support order visualization, workflow updates, and daily KDS applications. Kitchen Connectivity: 2.5GbE, 4× USB 3.2 Gen 2 ports, two RS-232 ports, HDMI, VGA, and audio interfaces connect displays and back-of-house peripherals. Environmental Protection: A fanless design, IP40 enclosure protection, and an operating range of 0–60°C with 0.7 m/s airflow support long-hour indoor kitchen use. Compact Installation: A 180 x 150 x 35 mm chassis, 12 to 24 VDC input, and 75 or 100 mm VESA mounting support clean behind-display deployment.
Interactive Display
The ITD-2000 Series gives kitchen staff a durable touch surface for viewing orders and updating workflow status. Readable Information: FHD resolution, wide viewing angles, and anti-glare treatment keep order information clear across busy kitchen work zones. Staff-friendly Touch: 10-point projected capacitive touch with glove support enables direct interaction without interrupting food preparation workflows. Easy Cleaning: The true-flat IP65 front resists dust and splashes, while IK08 impact resistance supports repeated daily use and sanitation. Flexible Integration: Multiple display sizes, portrait and landscape support, VESA mounting, full-function USB Type-C, and built-in KVM control accommodate different kitchen layouts.
Business Value
The combined platform helps restaurants digitize kitchen communication without adding unnecessary installation complexity.
For Kitchen Staff: Clear order sequences and responsive touch interaction reduce reliance on paper tickets and verbal communication, helping staff act on updates faster.
For Restaurant Operators: Commercial-grade protection and fanless computing support long operating hours, while a cleanable display surface helps maintain daily hygiene routines.
For System Integrators: Rich I/O, standard VESA mounting, compact dimensions, and a consistent ITD display platform simplify enclosure design, cabling, validation, and multi-site deployment.
-50/DS-351_03--(2)20260918171139.png)
-50/DS-380_PIS20250826101616.png)
