Case 1 - Comprehensive Sanitization with the UV Disinfection Robot
- AI can replace humans with robots during a pandemic to significantly lower the risk of an infection and maintain a safe environment
- The built-in AI is capable of predetermining the optimal path to avoid obstacles.
Case 2 - AI in Medical Navigation
- Dual 4K and full HD video capture cards: The USM-500 comes with two video capture cards supporting 4K and full HD resolutions, enabling seamless capture of large video files and real-time AI algorithm execution.
- Real-time AI algorithm execution: With its video capture cards, the USM-500 enables users to execute AI algorithms in real time, enhancing efficiency and enabling swift insights extraction from captured video footage.
Case 3 - Robotic Assisted Bronchoscopy Platform
- Ensuring stable operations of two high performance computing systems in a single OR kart system.
- Take advantage of the RTX A4000, suitable for real-time image processing in confined spaces.
-50/RTX_A-Series-A4000_3QTR-TopLeft202110081116562022093009514220230221113753.png)
-50/a100-pcie-1331338-press-2000x150020220916112757.png)
-50/ICAM-520_06--20231101152200.jpg)
-50/MIC-71320240411132751.png)
