Advantech Edge AI System Application Cases - AMR & Cobot
Estudos de Caso 20/09/2024
Bringing AI to The Edge - Advantech Edge AI System Application Cases
Case 1 - Comprehensive Sanitization with the UV Disinfection Robot
  • AI can replace humans with robots during a pandemic to significantly lower the risk of an infection and maintain a safe environment
  • The built-in AI is capable of predetermining the optimal path to avoid obstacles.
Case 2 - AI in Medical Navigation
  • Dual 4K and full HD video capture cards: The USM-500 comes with two video capture cards supporting 4K and full HD resolutions, enabling seamless capture of large video files and real-time AI algorithm execution.
  • Real-time AI algorithm execution: With its video capture cards, the USM-500 enables users to execute AI algorithms in real time, enhancing efficiency and enabling swift insights extraction from captured video footage.
Case 3 - Robotic Assisted Bronchoscopy Platform
  • Ensuring stable operations of two high performance computing systems in a single OR kart system.
  • Take advantage of the RTX A4000, suitable for real-time image processing in confined spaces.
