Discover how the ICR-1745 5G gateway ensures reliable, high-speed connectivity with Wi-Fi 6, VPN security, and centralized management for any scenario.
With five Gigabit Ethernet ports, digital I/O, and serial interfaces, the ICR-1745 easily connects both IP devices and legacy equipment to modern 5G networks. Integrated VPN support, connection monitoring, and automatic recovery mechanisms help ensure secure and resilient operation, even in unattended or harsh environments.
Its flexible system-on-module design, combined with the open Linux-based ICR-OS platform, allows customization through scripts, C/C++, or downloadable RouterApps to extend standard firmware functionality. The router is also easy to manage at scale via WebAccess/DMP, a cloudbased platform for device management, provisioning, and monitoring – making it ideal for mass deployment, remote management, and secure VPN access.
Whether for environmental monitoring, mission-critical machinery, IP surveillance, or providing high-speed Wi-Fi hotspots, the ICR-1745 acts as a versatile building block, supporting a wide range of industrial M2M and IoT applications. The following use cases illustrate how it can be deployed to deliver reliable connectivity, enhanced operational efficiency, and seamless integration into complex networks.
Challenge
Solution
The ICR-1745 combines 5G connectivity with Wi-Fi 6 to
provide reliable high-speed internet for multiple users.
Integrated VPN support, continuous monitoring, and
centralized management via WebAccess/DMP allow
administrators to configure, monitor, and maintain the
network efficiently, even across multiple locations. The
router’s robust design ensures stable performance
under heavy loads and in diverse deployment environments.
Benefits
• Reliable Wi-Fi 6 performance combined with fast 5G uplink
• Secure network operation and traffic control using VPN and firewall features
• Centralized hotspot and device management via WebAccess/DMP
Use Scenario
-50/ICR-1745-CN_Wall_001_PIS20260107150613.png)
-50/ICR-1745-CN_Wall_001_PIS20260107161103.png)
